Huawei B535 - Need some help with external antenna.
Hey wondering if someone can assist before I pull the trigger, I'm using a Huawei B618-65d - I've worked out the connector on the back is called a "TS9" so can I buy an adapter like this?
TS9 adapter (takealot)
Looks like I need to two of them or do you only use one of the ports?
Will that allow it to work with any SMA type antenna?
Yes, that will work. I'm using two of these with a Poynting antenna: https://www.takealot.com/rf-adapter-sma-female-to-ts9-gold/PLID60539846 slightly tight fit, but works well
Wow ... what an insane price for an adapter.
Care to elaborate on that point?
Yes, expensive but they work.
Previously I had the lead adapters, however, they were much more susceptible to being accidentally pulled out when working in the area. Perhaps partly because the lead adapters are thin and light whereas the antenna cable is quite heavy. These small adapters leave very little room between each other, but I trust this way more than the leads.
So I moved into the sticks.
I'm getting low signal quality, but very decent throughput.
26ms latency and averages of about 43Mbps download. Upload is low, but not a concern for me.
I'm fine with it. I don't want to invest more money in a connection for the purpose it serves.
Thanks again for the help.
Hopefully this thread will help others too..
  • Love
Reactions: Yuu
So which antenna(model) did you end up buying? I don’t see you stating which one you bought, and so far has it given you reliable speeds?
Hi,
As grace would have it, I've got better signal where I am now with speeds hitting up to 90Mbps at times.
I didn't need to buy an external antenna.
I only used the Huawei App on my phone to get an optimal location where to place the router.
Aside from the fact that I completely lose connectivity on some days, I don't have any issues with signal.
The lack of connectivity seems to be with the tower though. Theft, electricity, not sure to be honest.
Edit: my earlier post was when I didn't have optimal placement of the router, so I only hit 43Mbps.. It's improved a lot now.
Hi,
Oh wow such speeds I guess you really have an improved tower nearby. And I guess it’s not Rain but another network, maybe Telkom. Ok then, thanks for your response... I’m getting an antenna tomorrow so I’ll see on my side what will improve, this is for Rain.
