Need help with cellc mms setting with autopage.
Foamy
In connected with cellc through autopage. Can someone please tell me how to get my mms enabled, it would be much appreciated. My phone is a d820. Thanks
I have normally had a good relation with CellC, but when it comes to MMS settings, they stink.
There are 3 options you can try.
1. Send an SMS to the following number 0841559911. The subject of your SMS should read MMS.
2. Phone 140 and get them to send you the setting over the air.
3. Log into your account on www.cellc.co.za and use the net to have the settings sent to you.
Don't hold you breath with any of the above. I think it only works 20% of the time. But, you may be lucky.
The 4th option, by far the best, is to try and find the Samsung mobile phone support page, and then hope that they have a facility to send you phone settings.
FOUND IT: http://za.samsungmobile.com
