MartyMarts
Spontaneous Interruption
- May 16, 2006
Hi
I have a Nokia 6220 and am currently connecting to my laptop via an infrared connection and then using the 6220 as a modem (using a GPRS/EGPRS connection to the internet). It says I'm connected at 115kbps which is also the maximum connection speed of the infrared/irDA port (apparently). Doesn't seem like a 115kbps connection though.
I would like to know if it's feasible to buy a USB data cable (either a CA-42 or DKU-5 cable)? i.e. would my connection speed increase considerably? Would I then be able to fully utilize the speed of a GPRS/EGPRS connection?
I'm pretty new to this, so I will appreciate any advice...
Thanks!
Thanks!
