I found it the using the following steps:
- Click on the link in the previous post.
- Select "Notebooks" in the Product Search box. (If you don't see the Product Search box, clear your cookies. I used IE since the site also had trouble displaying properly in FireFox, didn't recognise that cookies was enabled)
- Another box will appear next to the current one, select Amilo.
- Next box, Amilo M Series.
- Next box, Amilo M7400.
- The downloads page will appear, select "Select all" as the category and operating system and click Go.
- Scroll down in the Download results window until you find "Application Panel - Launch Manager - Licence Software" (if the page does not appear allow pop-ups)
- Click on the link, accept License conditions and download driver.
The site is a bit dodgy but if you use variations of the above or search for Amilo M7400 you should get to the correct download.
I tried getting a direct URL and found the following. Not too sure if it will work from your side since it could be dynamically generated:
http://support.fujitsu-siemens.com/...leNameClient=FSC_1000929.zip&FileSize=1939453
Good luck!
