Razer Blade 14 Laptop - Problem Starting
Well, please keep us up to date as you trouble shoot this. :)
This will be a slow burn repair. Will probably take a couple of months.
I fully accept that I'm going to have to debug which chips on the mobo are faulty and then find and import replacements , as well as a soldering template. I'm then going to have to risk torching everything by desoldering the old chips and soldering on the new ones. I might have to have a few gos and spend several thousand to do this.
It may or may not be worth it. We'll see.
If you went into this repair knowing and expecting this level of problems - I take my hat off to you! Good luck!
