Derrick
ლ(ಠ_ಠ )ლ
- Nov 22, 2010
What distro? I hope its Linux Mint...then the drone can play DVD's out of the box!!!![]()
Isn't that against the GPL? If you combine GPL code with classified code then per GPL rules the GPL code plus the modifications (the classified portion) must be released as source, no?“The US government can directly combine GPL and proprietary/classified software into a single program arbitrarily, as long as the result is never conveyed outside the U.S. government, but this approach should not be taken lightly,”
Drone software isn't likely to be MS based either.Ground control software, not the drone software.
Interesting. I thought the terms kick in when its modified, but you're quite right its when the program is distributed. Learned something new there....I think you missing the point of GPL.
