Hard drive and SSD technology improvements continue
And to think that last year I bought a Vertex 2 60GB for R1200, these days you can buy a SSD that is double the size and double the speed for cheaper.
My advice from prior experience: Stay away from OCZ. Had two drives fail on me in two months. No support from vendor, and no proper firmware update cycle.
They're relatively new to the game. I trust the likes of Intel and established brands.
Personally I will never buy OCZ again.
Sorry to hear about your problems. On my side everything is ok though. My old OCZ still works without missing a bit. And 2 months ago i bought a 128GB one and is even faster. If 2 ssd's failed consecutively, have a look at your power supply and/or mother board. SSD's are sensitive to voltage fluctuations/spikes
They were installed in different machines, and both on UPS.. different make/model UPS
Never thought I'd see the day when 6 Gigabit/sec drive channels are considered bottlenecks.
Bloody awesome.
I have a Samsung 830 512Gb SSD in my iMac and its a wonderful drive. Apparently one of the most reliable and the main reason I praise it is because it doesn't use data compression like those with Sandforce chips and therefor it is faster when using with an encrypted partition.
I had the V2 120GB and it died after about 10 months. I sent it back to Sybaritic and a week later it was replaced with a V3 120GB. The V3 has been fine so far.
I have also purchased a V4 256GB for my PC as their controller issues are apparently resolved now.
Would not write them off so quick. Their drives are pretty good.
In 2008 the Samsung 60 GB SSD cost R10,000. My Lenovo X300 came with one. It's still working fine with zero problems. It's only 100 MB/s but still feels fast.
+1 to what biometrics said.
I'm still using my OCZ Vertex 30GB, which cost me R1400 in 2010, even though I imported it!
It is still going strong with Ubuntu on it and it is still pretty fast in comparison with a normal HDD.
I now recently bought an OCZ Agility 4 128GB, and it is also working rather well.
If you had issues with RMA, then you should just use a better retail shop - like Wootware/Prophecy Shop.
These 2 shops has helped me so much in the past with RMA's! They really went out of their way to get things swapped out/refunded for me.
What a revelation this article is. To think that there could be a relationship between time and cheaper faster computer technology. I'm stunned.
I bought my 64gb for R 1700, so paid R 500 less than me. Though I had my SSD fix earlier than you, so the R 500 premium was worth it.
To someone like me who doesn't follow developments in SSD technology closely, and don't know how much the prices have dropped, it's a nice summary of the state of affairs.
I find SSD very strange as there seems to be a lot of consumers using it but in the business sector we have not even looked at SSD. We are still consistently using SAS drives.
In the enterprise sector SSD's has been around for quite some time, especially with big database systems where you need lots of IOPS (input/output per second).
Just have a look here:
http://www.slideshare.net/gharriso/ssd-and-the-db-flash-cache
http://www.slideshare.net/rajadurai/ssd-based-storage-tuning-for-databases * Rather old (2009)
If you're not using SSD's at your office, then you're definitely behind the trend!
Know what you mean. I bought a 120GB Agility 3 in the beginning of this year for R2100.
I have an OWC Mercury Extreme Pro 3G for over a year now. It's a 512GB SSD but only shows 480GB - as the remaining data is for over provisioning which allows more efficient wear leveling - so the drive keeps the same speed over time.
Assembly is in the USA too which eliminates most faults and failures.
OWC also have a 960GB SSD out but that's a RAID-0 combo of two 480GB (512GBx2) drives. I would stay away from that because of the dangers inherent to RAID-0.
