I've given up on trying to decipher the geek-speak all over the net when this question is asked. My setup:
Openelec
D-Link 2750U router
Numerous wireless connected machines
My transfer speeds from my Windows machine to the Openelec box (or vice versa) are max 5Mbps, and this is indicative of the other machines which are no quicker (Macbook, tablets, phones etc). My connection speed is 72Mbps (set to auto on the router) and at 40MHz in both bands. Whenever I change the rate the transfer speed appears to drop down to between 2 to 3Mbps. Changing to 20MHz in both bands doesn't help apart from changing the values of the connection rates I can change. Changing to mixed mode means none of my machines can connect to the router.
So what is going on here? My Netgear DGN2000 also shows transfer speeds of 3Mbps. BTW it isn't a problem with structural interference as I have one of the laptops right next to the router now and there is no change.
My Windows machine has an Intel N-130 wireless adapter. Any help would be appreciated...
Openelec
D-Link 2750U router
