DSTV - Signal Problem on Vertical Polarisation channels
Mark051
Hi All
I'm having a signal problem on some of my DSTV channels, but most channels are still fine.
I've noticed the problem channels are History and National Geographic.
I'm not a complete Techie but I know enough to realise that the problem is only being experienced on those channels broadcast in Vertical Polarisation (Whatever that means ;) )
Any help will be much appreciated!!!
This points to your LNB & dish not being correctly aligned. You can try adjust it slightly yourself, just get someone inside to keep track of horizontal & vertical signal percentages as you move, otherwise get an installer in
2 things, either faulty LNB , or the skew angle is out, if you standing infront of the dish, looking at the lnb from the front , it should be roughly in the 4 o'clock position
