isie
- Jan 16, 2010
So I ended up with an Eaton UPS for no cost (Helping a friend out sometimes has more then its own rewards), its been lying around doing nothing - the batteries seem OK. I tested it to run my TV and media player, and only uses about 6-10 % load so should be good around 2 hours during load shedding.
Only thing is its noisy as hell, both on battery and AC. I get the noise under Battery but not while AC.
Any way to silence it, sounds like the fan and some other hum.
