Digitaluser
I have been told that I have been upgraded from 1 to 2 megs but my internet Gateway connection window shows 1.5Mbps. My Actual dowload speed is 1.2Mbps - Which is correct 1.5 or 2
What kind of ISP account do you have, capped or uncapped?
If uncapped, and you haven't upgraded your ISP account, they will limit you to the speed specified on your account with them.
If capped, you should get full line speed, but this might be influenced by a variety of physical attributes. Perhaps the SNR on your line is too high to actually achieve 2Mbps, maybe you're too far from the DSLAM etc, etc. Have a look on your router at what rate your line is syncing at. Maybe that will provide some insight.
