10 Mbps fibre
iandoug
Hi
Someone I know needs fibre but package options seem odd ... 4 Mbps then next option is 20. Where's the 10?
This be Vumatel. I've checked Afrihost and WebAfrica ... who should I be checking?
Thanks, Ian
So noted, thanks.
It's a pity that "Don't be evil" idea never caught on.
The 4Mbps is pretty much break even for them.
Each Mbps higher you go is cheaper than the last one for them, so they try and start their packages at 20Mbps.
https://shop.vumatel.co.za/packages/all
is what you're looking for in regards to checking all Vumatel packages.
Most 20Mbps uncapped are cheaper than OpenServe 10mbps uncapped.
Thanks, forgot about checking Vumatel's shop page....
