Hello,
Suddenly tonight at about 6:00 PM 4/8/2015 I was in-game running smoothly at about 40 ms, when suddenly my ping is spiking between 1000 to 3000 ms. So i contact my ISP and he doesn't know what is wrong with it as he is seeing everything as fine so i decided to try my friend's ADSL account out from Web Africa, same problem, so it must be a line problem right?
So... I ran the "Is it my line tool" that i found in an awesome thread a while back and here is what it gives me:
Detailed Report:
So it is my line? What must i do? I have a 10MB line with Telkom and my ISP is somebody like IS i think.
Also i cannot run a speedtest, it is just frozen right now on selecting best server by ping. But when i ran the test earlier it gave me a download of 0.29 and and upload of 0.01.
Where my normal results are about 8.5MB download and 0.85MB upload.
I am just curious what i should do, if i phone telkom, what do i say or what?
Thank you for any comments
EDIT:
I forgot to mention, its not constantly high latency or ping it is low randomly and high randomly. More often higher than it is lower.
But here are some tests from when it was low:
Detailed Report:
Which is why i don't know what i should do, as it does it on all the ADSL accounts i have tried.
Detailed Report:
Code:
Pinging 155.239.255.250 with 32 bytes of data:
Reply from 155.239.255.250: bytes=32 time=1437ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1494ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1532ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1527ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1543ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1563ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1579ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1557ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1521ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1514ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1512ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1536ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1508ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1503ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1497ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1510ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1504ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1547ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1525ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1531ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1499ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1496ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1488ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1500ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1493ms TTL=63
Reply from 155.239.255.250: bytes=32 time=1552ms TTL=63
Ping statistics for 155.239.255.250:
Packets: Sent = 30, Received = 30, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1437ms, Maximum = 1579ms, Average = 1516ms
EDIT:
Detailed Report:
Code:
Reply from 155.239.255.250: bytes=32 time=7ms TTL=63
Reply from 155.239.255.250: bytes=32 time=8ms TTL=63
Minimum = 7ms, Maximum = 8ms, Average = 7ms
