±R3200 Intel Sandybridge lga1155 i7-2700K - Quad core+Hyper-Threading / 8 threads , unlocked clock multiplier , 3.5ghz box cpu / 3.9ghz turbo boost , VT-x + no VT-d + AES-N + AVX , no TXT , built-in dual channel DDR3-1333 memory controler , built-in HD3000 graphics ( 12EU , 850/1350mhz , dual stream video decode + HDMi ) , 8mb L3 cache , 95w- Quick Sync Video + InTru 3D + Insider + FDi + Clear Video HD + Dual Display Capable
http://ark.intel.com/products/61275/Intel-Core-i7-2700K-Processor-(8M-Cache-3_5-GHz)
±R1500 Asus P8Z68-V LX : all-in-one LGA1155 mb with SRT + iPT + EFi mouse-controlled bios + crossfire ready ; intel Z68 chipset , 4x dual channel DDR3 2200(O.C)/1600 , 6x s-ata with raid 0/1//0+1/5/10 ( 2x SATA6G + 4x SATA3G ) , on-board VGA with tripple -output ( HDMi + DVi + D-sub ) , with HDMi AV output ( HD DVD , Blu-ray 1080p HDCP compliant ) , on-board Realtek ALC887 7.1 with optical s/pdif out + gigabit lan ; 3x pci, 2x pci-e (1x) , 2 x pci-e 2.0 (16x+4x) for Quad-GPU CrossFireX ( no SLi ) , with 2x USB3.0 + 4x USB2.0 upto12 , support optional serial port add-on cable - atx
http://www.asus.com/Motherboards/Intel_Socket_1155/P8Z68V_LX/
±R1100 Corsair CMX16GX3M4A1600C9 , XMS3 with heatsink , 4Gb x 4 kit - support Intel XMP ( eXtreme Memory Profiles ) , ddr3-1600 , CL9 , 1.5v - 240pin - lifetime warranty
±R850 Coolermaster RC-550-KKN1 , Silencio 550 , no psu ( bottom placed design ) , black : with sound proofing side panels , front door with piano-black mirror finish + dust filter ; 1x SD card reader + 1x front usb3.0 + 1x front usb + audio in/out - 2/3 x 5.25", 1/0 x 3.5" , 7x 3.5" hidden with removable HDD cage ( side accessed ) , 2x 2.5" ( converted from 1x 3.5" ) , 1x SATA X-dock hot-swap bay in front panel - 2x 120mm fan upto 3 - atx
http://www.coolermaster.com/product.php?product_id=6702
±R750 Antec HCG ( High Current Gamer ) 520w ( 12v : 480w ) , with EPS12V v2.91 , 80PLUS Bronze certified ( 87% efficiency ) for energy saving - 24pin ( 4pin detachable ) ; 2x 8 (6+2) pin PCI-E 2.0 power connectors , 1x 135mm PWM fan with advanced thermal control , 6x SATA , 6x molex , with OCP, OVP, OPP, SCP safety standard - 3 years warranty
http://www.antec.com/Believe_it/product.php?id=MjQ1Nw==
R7,400
