2 Gang smart wi-fi switch wall mount
Vaughankzn
Hi
Guys can you recommend a smart wi-fi wall mount switch that is a 2 x gang and dimmable. Also does not require neutral I was hoping to Sonoff but can not find any that do this. Any advice is is welcomed
Hi
Not sure if you can have a wifi enabled device that does not need a neutral.
Not sonoff, but also uses ewelink
You may also want to check robofactory.co.za
If you cant find a solution in a switch version, you could install a dimmer and then pair it with a sonoff smart control panel that you can install anywhere.
The shelly dimmer 2 doesn't need neutral.
