Agent_B
Hi All,
My wife has a 2006 Toyota Tazz. A couple of weeks ago the dome light shorted and blew the fuse. I replaced the light and fuse. but noticed the that when opening the door the light will not come on. I suspect this is wired through the alarm as normally if you close the door the light will stay on until the alarm is activated. I decided to do a test and armed the alarm and then opened the door--- The alarm did not activate.
The alarm is the factory alarm from Toyota. Does anyone have any wiring diagrams or advice on fixing this?
