2020-vision-for-life
I am Penguin
http://www.geek.com/articles/news/light-adjustable-lens-promises-2020-vision-for-life-2009127/
A new lens may offer the perfect solution giving someone 20/20 vision without the need to wear glasses or contacts anymore. It is called a light adjustable lens (LAL) and replaces your eye’s natural lens.
well depending what kind of problems it can fix
5k usd per eye is a tiny amount relative to the change in ur life it can potentially make
Ey Sci_Fi films come to life, Cybernetic implants!
Cool. Obviously it also fixes any problems caused by a damaged/faulty natural lens
why would one do this if you can have surgery though?
For one they can "reprogram the lens" it seems with a wave?. Two its for a lens not functioning well anymore like when you age and it looses its flexibility. No operation can cure that, only lens replacement will work and this is a far more advanced lens than prior devices.
so.... r100,000 worth of surgery vs r500 worth of glasses... Rightio sounds great.
