I've got a 17" MacBook Pro ( 2009 ).
Under preferences, displays :
Color LCD 24” LED
640 x 480 640 x 480
640 x 480 ( stretched ) 640 x 480 ( stretched )
720 x 480
720 x 480 ( stretched )
800 x 500 800 x 500
800 x 600 800 x 600
800 x 600 ( stretched ) 800 x 600 ( stretched )
960 x 600 960 x 600
1024 x 640 1024 x 640
1024 x 768 1024 x 768
1024 x 768 ( stretched ) 1024 x 768 ( stretched )
1152 x 720
1280 x 800 1280 x 800
1280 x 960 1280 x 960
1280 x 960 ( stretched ) 1280 x 960 ( stretched )
1280 x 1024
1280 x 1024 ( stretched )
1344 x 840 1344 x 840
1344 x 1008 1344 x 1008
1600 x 1000 1600 x 1000
1600 x 1200 1600 x 1200
1600 x 1200 ( stretched )
1680 x 1050
1920 x 1200 1920 x 1200
As you can see there are resolutions supported by the Mac that is not supported by the 24" LED, if not mistaken I am sure both these screens supports the same resolutions. Got this info after reloading OS X. Would like to know if the info. is correct for the 24" display or are in fact resolutions missing that screen are capable of that mine can not display. I am 100% sure the 24" was capable of displaying 1600 x 1200 ( stretched ) which you can see is now missing from the 24".
Thank You
Color LCD 24” LED
640 x 480 640 x 480
720 x 480
800 x 500 800 x 500
800 x 600 800 x 600
960 x 600 960 x 600
1152 x 720
1280 x 1024
1680 x 1050
Thank You
