25cm fan
ive got an aerocool zero degree but the 25mm fan supplied is rather pathetic
a strong faster fan would do really well :)
I just looked throught every conceivable pricelist I have and I dont see one, but I'll try to find out from my one friend in Roodepoort, there are places that make fans for other industrial uses, maybe they have somethin...
ummm its big but slow doesnt move alot of air
i had a lanboi with a 120mm that i added to the side panel with another 120mm side fan both those where way better, moved more air
made my box alot cooler, im gonna struggle in summa with this thing
how do i give it more powa?
If you have a old psu you can play around with, cut one molex conector off and connect it's wires to one of the existing molex connectors. It should almost double the speed I think
