What like Java SE?
Well not to sound mean, I would recommend that you finish you words in your titles, as that can make or break a letter.
Other than that, I have all the utmost respect for someone that has the guts to be self employed. good luck with that!
Is this a job invitation, because I've done such projects.What else do you know apart from Java ?
Can you convert Visual Basic6 to Java or C# ?
Except that they have no idea yet. Which field/project would kick start three senior Java developers? any programs in need in South Africa, maybe government sector ....
you need to find a client... if you are jsut starting out and you are looking for you first project to require a3 full time senor devs's that might be a bit milestone...
Most of the work will come by word of mouth... so the best way to do it is to find 3 or four projects and have each developer work on one as part of a pseudo-company..
Then jointly code the generic lib's(logging, user auth, accounts integration, blah blah.)
and share infrustructure(soruce control, backups, email)
Use these building blocks to build the apps, one you have a good couple of building blocks you can knock up apps pretty quick..
What happens is you will find a project that will require more and more developer and staff.. one of the projects will be successful and take more and more time .
You can start by using rent-a-coder but to be profitable on this you need the building blocks already.
