30m ethernet cable
adamr
Fourways, Johannesburg
Will incredible connection sell this length of cable? ... or maybe slightly shorter will do also ...? need to connect my xbox to my pc router, and they in diff rooms ...
Prob not, but any decent pc shop should be able to hook you up with a custom piece. Some places tend to rip you off though, RJ-45's and boots are R1 a pair and cable is R2pm add a mark up for their “technical” part and you will have your price. Don't let them rip you off.
PS those are direct to the public prices, nothing fancy.
Typically you pay around R5 per metre for a custom cable in a store. If you buy a big one you may be able to negotiate a discount.
so i should not pay more than R100 for a 30m ethernet cable ...
That sounds about right. Check out Sybaritic, I've never had problems with them, I know Cyberdyne sells custom cables and I believe they are in the South (Roodepoort)
They are also relatively well-priced
