3g Help please
CrzWaco
Pretoria
Hi there
Not sure where to start but we looking into getting 3g while we waiting for telkom to install our line.
Things I would like to know can I use my phone as a 3g modem(it has a 3g lil icon next to my signal bar) and let everyone connect trought it?
Or do I need some special card/modem to use 3g?
Can I use bluetooth to my pc then share it so that 2 other pc can use the connection?
Looking to use gconnect as the isp or is there better deals out there?
You can use your phone modem, it's a normal dialup-connection that you share for others on your LAN.
gconnect? MTN or Vodacom are your ISP. Buy a data bundle if you're on pre-paid.
o okay I see thanks. So just buy a data bundle from vodacom and done
Hey Wacoface :p
yeh man, that's what I used to do.
dial *111#
250mb = R139
500mb = R189
it's kinda expensive, but it does it's thing if u need to check mail n stuff.
otherwise i would recommend picking up a 2nd hand HSDPA modem somewhere on the internets :)
