Krypt0n1te
Please help me with the following.
1. Internet source must come from TP-Link MR3020
Question is very simple but from all my reading it seems this can be very tricky.
EDIT: Forgot to mention. All connections must be wireless, thus no lan cable between 3G router and Range extender.
Q1. The person that needs this setup lives in quite a big and old (solid) double story house. Best 3G signal is on the top level on the "Left-side" of the house.
All we want to do is put the TP-Link WA730RE in the middle of the house (top level) so that it is extended from there.
Reading the instruction on the Range Extender this seems like a VERY easy task to accomplish, am I being fooled here?
I've got a MR3020 myself, the Router does have WDS in its settings and also a little AP, WISP and 3G switch.
Q2. Could this be done with a normal Wireless Access Point or is the Range extender the way to go?
Holding in a button for 5secs simply seems to easy!!
Q3. Would you suggest something else?
Thanks in advance!
Thanks in advance!
