4 tuner HD PVR not scanning enabled networks
cmj001
Johannesburg
Been trying to upgrade my 4 tuner hd pvr but alas no luck. The pvr simply refuses to scan all enabled networks and reboots after scanning 10% of networks ( tried 5 times). I live in a complex and with the new changes we've had to programme new frequencies to access all the new channels. That's when the cock up started. Anyone had this problem.... I'm dreading a trip to Multichoice but it looks like I might have to...:mad:
All the transponders don't have NIT information, causing this problem. Only add these:
Home Frequency +
10810 MHz with 30000 SR
10850 MHz with 30000 SR
10890 MHz with 30000 SR
10930 MHz with 30000 SR
11250 MHz with 30000 SR
11290 MHz with 30000 SR
11330 MHz with 30000 SR
11370 MHz with 30000 SR
11410 MHz with 30000 SR
OMG, I just want to say thank you! This POS 4P has been doing that all day with these new settings, was starting to think I would have to get someone out.
If anyone else from a single cable communal complex stumble upon this, those frequencies are only valid once the upgrade to the system has been completed.
