40 x Tablets in a cabinet @ ~0.7A each
AntiThesis
East London
OK so this is the deal.
I have 40 x tablets that draw a max of around 0.7A each when charging so for safety sake, let's work on 1A each.
I have a cabinet that I am retrofitting to store them in. I've fitted 220v fans to pull in cool air and push out warm.
Now I have to think about the best way to supply power in a way that will a) not burn down the building and b) be safe/OK with insurance and c) be legal.
The suggestion I'm NOT going to use is a piece of electrical trunking with 30 x female two prongs connected in parallel to a regular plug socket. From what I understand, that's silly since it's then 30A going to a max 16A plug.
Is the easiest/safest solution going to be regular multiplugs with say, 10 devices on each and then going to their own plug?
I'm more interested in WTF you're busy with - and is it 30 or 40 tablets?
Sorry, 40 :) The strip that I was given will take 30 but will probably burn the building down. Just what it says on the box - constructing a cabinet to hold and charge 40 tablets.
*heavy breathing*
Know if those are available in SA somewhere?
30 2 prongs with tablet chargers in them are not going to overload a 16A socket... It's a 1A charger at 5V which is 0.02A at 240V each for a grand draw of 0.8A total, double that for inefficiencies and you're under 2A, no need to worry.
Also your multiplug suggestion does exactly the same thing as your "definitely not going to do this" suggestion.
The single transformer above will be more efficient though.
You understand wrong. Your plug/multiplug/lead/extension can take 16A at 220V.
220 * 16 = 3520 watt.
Typical tablets/phones run at 5V say at 1A. 5 * 1 = 5 watt.
So because the charger down steps 220V to 5V it one tablet would be pulling like 0.02A at 220V.
So in theory you could charge 704 tablets from one 16A plug.
Thanks! That makes sense. So it's effectively:
1 [for one tablet] * (5/220 [for the stepdown]) = 0.023A per tablet so what, 0.91A for 40 [40 * (5/220)]?
Yip. Plus add some inefficiency buffer because step-down transformers aren't 100% efficient.
Get yourself a few PC PSU's - far cheaper than these other fancy devices.
That's actually the first thing I thought of when I saw the question: a 300W power supply should handle that easily. Then I thought that someone's probably already made one, so I googled "300W usb charger".
DIY would require some knowledge of electronics though and there are lots of other factors to take into account.
You didnt tell us what you are doing with them. Please, for the sake of the children, spill them beans.
