howardb
My line has been running fine for the last month, until late last week. The modem would sync at 4096/512 down/up respectively.
Since late last week, the modem shows the following:
SNR Margin (dB) Down: 10.8
SNR Margin (dB) Up: 12.0
Attenuation (dB) Down: 54.0
Attenuation (dB) Up: 30.5
Output Power (dBm) Down: 10.4
Output Power (dBm) Up: 18.8
Attainable Rate (Kbps) Down: 3296
Attainable Rate (Kbps) Up: 844
Rate (Kbps) Down: 2048
Rate (Kbps) Up: 512
It will not sync above 2048/512 and it shows the highest attainable rate as 3296/844 ???
Telkom have tested the line and said all is ok.
My ISP has checked the account and says it's fine - no throttling on the line.
I've checked all the plugs and connections.
Voice line is crystal clear - no audible noise noticed.
So, question is, where to next? Beginning of last week it sync'd at 4096/512, this week, not...
Rate (Kbps) Up: 512
