560 temps
Curryboy
hi
I just bought a gigabyte 560 ti OC about 2 weeks ago, my other specs
i7 2600
4gb ddr3 RAM
1 TB hdd
intel Burrage p67 mobo
nvidia 285. 38 beta driver
i was wondering is it normal for a card to idle at temps to be at around 42 degrees celsius? because like when i play rage on max etc it doesnt even go over 50 c so could the beta driver cause the card to run at higher temps? or is this a general problem with the giga 560 ti's? (temps still the same if i take the side case cover off
ok cools thanks! i have seemed to sort it out just updated to lastest nvidia drivers now it idle in the 30s
