6v Rechargeable Battery type?
howardb
Randburg, JHB
Hi all,
I've got an LED battery-powered rechargeable lantern from a number of years back, however the rechargeable batteries no longer hold charge when charging. After some testing, I've established that the 3 individual batteries are rechargeable 6v, with the 3 batteries joined in parallel.
As they are knackered, I decided to crack one open and found per the photos - anyone have any idea what battery type these are? There are no markings, other than the letters L and F on the top by the +/- terminals.
It also seems to have 2 holes at the top which had small rubber covers pushed on, making me think it was a gel-type or partially sealed-type battery. After cracking the one open, I see that it is totally dry inside, and seems to have alternating layers of white cloth-type plates with the metal electrode plates from the +/- terminals sandwiched between each layer - seems to have 7 layers in total...
Any suggestions as to the battery type - I've never seen these types before... hoping to either find a similar replacement or figure out another battery solution that will fit inside the LED lantern unit.
BTW, the measurement of each battery is 64mm x 35mm x 23mm - seems to have only soldered +/- terminals on each.
Searched a bit, but cannot find any information or similar looking battery.
hmm maybe not just best to buy a new small one, i think they go for like R200
Thanks guys - the more I read, it seems to be a 6v Ni-Cd, however also cannot find anything similar in size. Was hoping to just replace the batteries, but will probably just trash the entire unit and replace.
Try and Google Lantern name for possible more info-who the agents are.
If you take the battery price of ~R100 from Communica + their courier fee of ~R70 it's nearly better idea to get a new Magneto Lantern for R199 from a few suppliers like Builders, Makro or Game.
