Hi
I'm battling to get a my pc to use the Router's ADSL connection. Initially it would allow me to view the login page of the router but if I attempted to log on with the correct username and password, it would say it cannot display the webpage. I've checked the router by connecting it to other pcs and it works perfectly, and gives the connection. The router hasn't been played with at all,so I don't think it is a likely candidate for the problem.
After fiddling around I realised it was most likely a port issue, so I deleted BitDefender and was able to log on to the router but, no luck with the connection.I've tried using the USB connection to the router to make sure it wasn't the on board network card,with no success. If anyone could help, I'd really appreciate it.
Many thanks in advance
