Lets start at the beginning,
The two front USB ports on my PC dont work, first it was one port and now the other as well. I used to have a problem with a windows balloon thing always coming up and saying USB device not recognized although there was nothing plugged into the front and only 2 printers in the back which work fine and appear in device manager. Device manager always shows an unknown device though, and I dont know what that is referring to. But most importantly I need those 2 front USB ports working, and they are connected to the Mobo (I checked).
Next prob, started when the electricity tripped.
Occasionally my screen just "Blacks out" like it stops receiving the signal kinda thing, and after a few resets it comes back on. Problem two, sometimes after one of these resests as the pc turns on there is a continuos series of "Long Beep - 3 sec paus - Long beep - 3 sec pause........" and after a few resets that also comes right. And then yesterday when I reset it the one day the power light on my box just kept flashing, with only the fans spinning, I had to turn it on and off to get the pc to boot.
So whats your bet?
So whats your bet?
