A problem with ports conflict
kronoSX
Capetown home to gang stars
This is the setup.
front usb has a blueteeth dongle in.the rear usb has my usb 3g modem in(aka...n70).
This is the problem when i connect to the internet i get a error that there is a conflict of hardware and the port is already in use.
I checked the modems port and its on com14 and all blueteeth ports are from 13 to com 2.
When i diagnose the modem it tells me the port is already in use or there is a conflict with my hardware....I did check device driver for any conflicts,but sadly there is non.
Now the only way to fix this problem is to uninstall bluesoliel software.Then i switch the modem(n70) off and back on again,..right that works,but not allwayz.
Is there a fix for this,It only happens when i install the blueteeth software.I cant control what ports the blueteeth will be using.:confused:
