Ok I have been trying out Gordian Knot to convert my vob files into avi. I was using Dr.Divx but have been having issues with the video and sound being out of sync. My problem is say for eg. I bring in a video vob with a resolution of 1024 by 576 into DGindex it shows it as being 720 by 576, and then when I want to convert it with the xvid codec it treats the input d2v file as 720 by 576 instead of the higher resolution I started with.
I can find no way to keep the input resolution the same as I started out with so that my final avi file is also 1024 by 576 (unless I upscale with xvid from 720 by 576 to 1024 by 576, but then I lose out on quality). I must be missing somthing, with Dr.Divx it is so easy.
I did try posting on Doom9 forum, but I have to wait 5 days minimum after registering to post....
