AC300 Inverter Module Generator
morbill
Port Elizabeth
Hi has anyone have feed back on the above unit ?
Thanks in advance
Thanks in advance
You are aware that this is a 120v unit giving only half of the bolt age needed to run anything in South Africa?
They may have mistakenly put up the specs and pics of the 120v model, but you do get it in a 240v model. However, you would still need their proprietary battery back (B300) for it to work. This battery pack will cost more than the inverter itself.
