I suspect that you did not get an internet connection for the sole purpose of running speed tests on it consistently, so you are not very fudged at all..
The result of one single speed test to one server does not necessarily provide a very good indication of your internet connection overall..
There are many things at work in the background that could result in the speed test you have there..
Hi guys, feedback on the above. All has been resolved. Turned out there was an issue with my router. Firmware update and a reboot on my side, all is well
