I've got a client with ADSL problems. Line is VERY slow at times, but never completely dead. Changed router and ISP, same problem. Telkom did line tests from there side, no fault found obviously.
Here is stats off the router:
Upstream 512 kbps
Downstream 4096 kbps
Noise Margin (Upstream) 13.0 db
Noise Margin (Downstream) 19.0 db
Attenuation (Upstream) 5.0 db
Attenuation (Downstream) 13.0 db
Can anyone tell me if these starts are good / bad?
Thanks.
Upstream 512 kbps
Thanks.
