Active Aligner (Feedback and thoughts)
prejoh
I am looking at using Active Aligners to straighten my teeth, see link for description of the product (shorturl.at/bfvw3), these are those see through plastic tray mouth guards that straighten your teeth. This is instead of the old school metal braces.
I have looked online and there is no local reviews of the product and its results, other than off course from the company itself.
My question is to those who have used it:
1) Did it achieve the desired results (i.e. were you happy with the outcome smile and teeth straightening)?
2) How close was the timeline they indicated to the actual time it took? i.e. mine says that it will only take 12 weeks
3) Anything else I should know?
They are quoting the all in for R30000 excluding any additional x-rays.
