ADSL 1 Bit Constellation.
nav122001
Hi,
Can anyone clarify me about "1 bit constellation" requirement in ADSL2/2+ standards ?
As per my understanding goes we support 1 bit constellation in ADSL2/2+ standards. So what configuration should i do in my CO / CPE system so that all my downstream bins (33 to 512) uses only 1 bit.:confused:
I have seen sometimes due to line conditions and low SNR, some tones use 1 bits/bin. But if i want to load only 1 bit in all bins what configuration should i adapt in CO/CPE. Iam not bothered about the resultant synch up rate. Iam only particular about the 1 bit usage in all the bin.
Is my understanding right on "1 bit constellation" first of all ??
Regards
Peter
