Adsl And Cordless Phones
sreddi
Vorna Valley, Midrand
I have a 2mg adsl service and a cordless telephone connected to the line. I get 1.1mbs on the line with the phone connected.
When the phone is disconnected I get 1.6 - 1.8mbs.
Does the telephone system take up 400-600 kbs?
Is there a telephone system that does not take up this much bandwidth when not in use?
Thank you for any responses.
Is it a Telkom approved phone? Trust me ,that is a very important factor.
Yes it is a telkom /Icsa approved phone and yes its connected via a pots filted.
Sounds like the phone is causing noise on the line. I had a telkom tech at my house just a week or so ago, he suggested we replace two of the devices, but stay away from cordless devices.
I had a similar situation with a standard desktop 'phone: when the 'phone was plugged in the SNR dropped considerably.
The solution was to replace the unit.
Yep, to be 100% safe, replace both the handset and the filter regularly. This lightning and power surges in SA make havoc of our equipment. :(
Are you using Wifi? If yes its because both wifi and the cordless phone are using the 2.4gHz spectrum and causing slow downs.
^This
I've been using cordless phones for years through 4Mbps now 10Mbps on my ADSL line and never noticed them impacting download speed.
^This
The cordless unit was connected via an old Telkom installed extension.I have bypassed the extension and the Adsl speed is now at 1.4mbs.Looks like there is a fault on the extension.
Thanks for the tips.
Interesting info .. thanks. Although we use a direct Ethernet connection between our wireless ADSL Mecer router and 1 x PC, plus 1 x laptop, our mobile devices (2 x android tablets, plus 2 x android phones) connect via WiFi to that same router.
I get frequent drops in ADSL and WiFi signal (but landine is working), which a router-reboot usually resolves. I now wonder if the 2.4gHz issue could contribute to the drops. We also have Telkom cordless handsets in 3 rooms of the house (study - where my wireless router is, plus kitchen, plus bedroom.
I stand to be corrected but believe that ICASA approved cordless phones conform to the DECT standard and operate on 1.9gHz.
Can someone more knowledgeable please comment ...
