Hello Dear Sir/Madam men, I'll try describe my situation with bad ADSL MODEM /ROUTER combination, and asks if you know something about of this kind bridgings ADSL ROUTER/MODEM which goes in switch (10 / 100 / 200 Mbps Gembird), and other 4 computer 4 which goes in switch!
DHCP has been enabled, because I use the modem/router in PPPoE LLC MODE, because do not succeed that changes PPPoE of LLC in BRIDGE MANNER which us will enable that go to the Internet with 3 computer in my LAN independently one of other, and this is a reason that must will use PPPoE ALWAYS are joined the option, because we only this manner enable that connect all 3 would count on the Internet
http://
The main reason that needs bridge MODE, am the option that can make the icon for the Internet connection with new connection the wizard from XP SP2 (ACCESOIRES/COMMUNITACION/NEWS CONN WIZARD), and after this that can will connect and exclude when I wish, that MODE I have used before with my Siemens modem 4200 model, but now I cannot with PTI 8411, cause I not always do wish enter my router connects and exclude, and 3 other computers...
I will explain how have been connected my small LAN in my house, PTI 8411 with the UTP CABLE go in switch (GEMBIRD), and the friend 4 computer go in SWITCH, and of SWITCHA they take the stub flange, I think THAT not AM the problem which uses switch for my LAN, and that is not the problem that which has not joined computers directly in PTI 8411, because is and switch the only dot of stub flange, and that is the problem with PTI8411, and PPPoE works with like this explained LAN stub flange PTI 8411 in the switchu and computers in switch, like a knife through butter, problem is alone I cannot set up the bridge mode!
Have tried, both options, when wizard FOR BRIDGE - 1483 BRIDGE IP LLC, show the IP -dynamic, or STATIC, with dynamic does not succeed,
but when have tried choose STATIC IP, and would put for Static Address 192.168.1.33, and for the sub-network mask - 255.255.255.0, And In the TCP/IP of assumption my LAN MAP-Yukon gygabit Ethernet CARD, would put the IP manually 192.168.1.33 and the same sub-network mask, and the DHCP has been disabled, I succeed make the bridge mode, with the option will connect and goes on the Internet, with the Shortcut for the Internet connection, but unfortunately only for 1 computer in the network is this would work and that that has been the computer, from which I would follow the setup wizard
some men are we would propose, that change in assumptions in the WAN, for the bridge yes put 1483 bridge IP LLC, BUT to no avail!
do I need do need will join in NAPT for the bridge mode?
I do not know do need put into this menu - WAN of assumption, for bridge MODE, user name and the password in the PPP to the section? In my case, I have put before user name and the password on the option forever and these data have stayed turn gray the colour and after have put the new management software, I have not been able will change them, right away when alone they would register inside!
Really i'M so tired, of the given trying that always get rid of this really bad problem, and again without success
Als I believe that are possible bridge MODE for my LAN - 4 computers., and hope that YOU will help that get rid of that problem:!
In advance large acknowledgements for your amiability
really i'm sorry because of my bad English, but that is not my native language
once big sorry, and big greetZ!
http://
