ADSL Connection Problem
booya30
Having a problem connecting to the internet.
This is the setup
Line--->>ADSL Modem--->>Linksys WRT54GL Router--->>Switch--->>File Server/ Print Server/ Computers
The ADSL went down yesterday. I phoned Mweb and they say they can see the connection is on and functioning on their side.
When I do a traceroute this is what I get:
Tracing route to www.l.google.com [74.125.95.147]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms DD-WRT [192.168.1.1]
2 12 ms 11 ms 11 ms dsl-244-0-01.telkomadsl.co.za [41.244.0.1]
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 525 ms 599 ms 599 ms iw-in-f147.1e100.net [74.125.95.147]
Trace complete.
It shows that it reaches the website, but it doesn't on Internet Explorer..
Telkom did phone yesterday and say there was a problem in the area. (Greenside, Linden) but said it should be fine by now.
Could it be this - http://mybroadband.co.za/vb/showthread.php?t=206066
Anyone have any advice?
Thanks in advance :)
Try using a different adsl account maybe? try using [email protected] with password guest( think that is it) and see if you can access www.telkom.co.za or telkomsa.net?
I have 2 adsl lines connected to the linden exchange and both are up and functioning at the moment.
EDIT: remembering now, the linden exchange does have more than one dslam. Both my lines are connected to different dslams. Seems yours is connected to the one which is faulty. Try calling telkom and ask them to do a line test. They should be able to pick up if there is any traffic coming from that dslam
