adsl line help
KYLEROX
hello guys i have uncapped adsl at work from telkom and at home i have just the normal landline
i want to get adsl at home too but i dont want to spend alot i want to use my username and password from work and get a router for home
what do i need other than a router to do this and how much it will cost?
Should the account be unlocked (not locked to your work number) all you have to do is enable ADSL and pay for line rental.
Then unplug your router at work and plug in your house router with the correct details and it will work.
But you will have to unplug your work router every time you leave to go home and also unplug it when you leave for work.
Around R150.00 extra to have 2Mbps ADSL added on top of the line rental.
You could take the router home with you every night. Saving every penny
