Oh okay, sorryAngellus said:Not the actual speed you get I am talking about the line speed that your router reports.
ATM my router reports 512K thus I will not be able to get 1024K when it comes out.
Modem
ADSL Firmware Version 3.00.12.00
Modem Status Connected
Connect Mode G.DMT
Down Stream 512kbps
Up Stream 320kbps
VPI 8
VCI 35
Correct - at the time of installation my router reported similar numbers. These were never the speeds I was able to obtain though - I wish they had been! It went fast mode - interleaved - then back to fast mode for me.MansoN said:Angellus, how do you know that you won't be able to get 1024K when it comes out?
If I remember correctly, my router and most other people's used to return 2048 kbps down, 640 kbps up when ADSL first came out. When they did that whole change from fast path to interleaved, all the speeds got adjusted (lowered).
I'm sure it'll get adjusted again accordingly when 1mbps is released.
Angellus said:When was your speed changed to that? If you don't mind me asking what area do you live in?
