ADSL over ISDN - possible??
tRoN
Hi
I have an ISDN2a line at my business which I installed for a Siemens ISDN mini PBX type phone which works great.
Can I install an ADSL internet line for data whilst still retaining the ISDN for voice???
Hi
No (at least not in SA). The question has come up a few times before:
http://mybroadband.co.za/vb/showthread.php?t=73911&highlight=ADSL+ISDN&page=2
http://mybroadband.co.za/vb/showthread.php?t=80845&highlight=ADSL+ISDN
Summary: You will need to convert to a standard analog line then get ADSL. Good luck!
Looks like you will need to install a second line. Keep the original for ISDN and the new one analogue for ADSL
Can a second line be installed in a premises if there are only 1 pair of copper coming in??
Uh ... a second line means a second line.
So that makes 2 pairs and 2 x line rental fees.
as far as I know it is theoretically possible since the ISDN uses the limited bandwidth scope that the analogue portion of your line normally uses. The ADSL uses the un-utilised portion of the line.
So these technologies should not conflict, but which goes where, I cannot tell you!
Well as far as I know Telkom usually install a cable which will support a couple of lines to a business premises even if only one is needed initially.
Yes it is technically possible, but Telkom won't install it. As stated earlier, order yourself adsl on a new line. If not needed for anything else, you could use the phone part included in adsl as a dedicated fax line.
And they have the cheek to charge you an installation fee when all along the extra line(s) have been sitting there from the initial installation. :p
