ADSL pricing
GuRu
Free Electrons
ADSL pricing: HELP
can anyone give me a break down of what one could expect to pay for a ADSL connection up 10Gig. ( Just doing some quick research :D ) including ISP..
Take a look at Axxess.
They offer 10 Gig Accounts.
Hellkom has a list of ISP's.
And Telkom for Line Rental charges.
Tks i did prices look great but i am undecided as to what connection to go with 384 or 512 ...
I am on 384Kb and it feels the same as the 512Kb, which I had before. I cant see any difference.
What you could do is even go for the 192Kb option and upgrade if you feel you need a bit more speed. Upgrades are free.
But if you are on 512Kb, it will cost you to downgrade to either 384Kb or 192Kb.
Just a small bit of advice. Buy your own Router. DLink, Netgear, Zyxel etc.
They are far better than Telkom's Marconi offering.
Tks
I was thinking along the line sof the D-link as i have used their equip. before and it seems the D-link has a better logging system..
Just make sure The Router has all the PPoe stuff onboard. That way you just log onto the modem using your browser and setup your details and settings. I did mine once and never had to reset anything again. So you can format your computer until you are blue in the face, you are still connected to the internet through the Router. It keeps everything in the "Bios/ROM" even if the power goes down.
Hope this helps. :)
ISP = Axxess
Router = D-link
Can't go wrong!
