I use MWeb and I haven't had any problems with connections or stability.
Today I signed up with Afrihost and purchased 1 GB prepaid. After going through the verification process my account was activated but I'm having problems. It seems only certain web pages will open. It doesn't appear to be random as to whether the page will open or not. What I mean is that certain websites will never open (most that I've tried) and certain ones always do (such as Google and Speedtest.net). I also can't connect to the PSN (Playstation Network). I tried using an old prepaid account from Web Africa that I haven't used in ages and it's doing the same thing as the Afrihost account. I emailed Afrihost and they said it's nothing on their side and "Please check that the DNS settings on your router are set to obtain automatically. If you are still having a browsing issue you can call telkom & have them re-sychronise your line."
Under "DNS" on my router (D-Link DSL-504T) all I found was "DNS Selection". It was set to "Use User Discovered DNS Server Only". I changed it to "Use Auto Discovered DNS Server Only" but this didn't help so i changed it back.
I don't know what it is when Telkom re-sync the line. Is this something that takes 5 minutes or do they have to go out to the exchange and it could take a couple days? I'm on a 512k line btw.
When doing the Speedtest, I noticed that MWeb uses Telkom but Afrihost uses Internet Solutions. I don't know what Web Africa uses but could this have something to do with the problem?
Hope someone can help!
