PhireSide
- Dec 31, 2006
Hey all
Did a ping test to Google.co.za to test, and I seem to be getting very erratic results using a 10Meg account from Axxess :erm:
Anyone else experiencing similar problems? I tried loading Speedtest off MyBB but it just shows a white screen where it is supposed to display
C:\Users\Phil>ping www.google.co.za -n 100
Pinging www.google.co.za [74.125.233.63] with 32 bytes of data:
Reply from 74.125.233.63: bytes=32 time=2634ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2062ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2255ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2162ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1649ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1533ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1764ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1814ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2046ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2428ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2743ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2629ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2422ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2142ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1852ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1057ms TTL=52
Reply from 74.125.233.63: bytes=32 time=596ms TTL=52
Reply from 74.125.233.63: bytes=32 time=227ms TTL=52
Reply from 74.125.233.63: bytes=32 time=56ms TTL=52
Reply from 74.125.233.63: bytes=32 time=68ms TTL=52
Reply from 74.125.233.63: bytes=32 time=62ms TTL=52
Reply from 74.125.233.63: bytes=32 time=61ms TTL=52
Reply from 74.125.233.63: bytes=32 time=57ms TTL=52
Reply from 74.125.233.63: bytes=32 time=298ms TTL=52
Reply from 74.125.233.63: bytes=32 time=612ms TTL=52
Reply from 74.125.233.63: bytes=32 time=659ms TTL=52
Reply from 74.125.233.63: bytes=32 time=691ms TTL=52
Reply from 74.125.233.63: bytes=32 time=770ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1039ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1280ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1601ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1989ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2448ms TTL=52
Reply from 74.125.233.63: bytes=32 time=3016ms TTL=52
Request timed out.
Request timed out.
Reply from 74.125.233.63: bytes=32 time=3171ms TTL=52
Reply from 74.125.233.63: bytes=32 time=3008ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1249ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1209ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1316ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1318ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1293ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1472ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1566ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2145ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2673ms TTL=52
Reply from 74.125.233.63: bytes=32 time=3221ms TTL=52
Request timed out.
Request timed out.
Reply from 74.125.233.63: bytes=32 time=3648ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2616ms TTL=52
Reply from 74.125.233.63: bytes=32 time=999ms TTL=52
Reply from 74.125.233.63: bytes=32 time=819ms TTL=52
Reply from 74.125.233.63: bytes=32 time=705ms TTL=52
Reply from 74.125.233.63: bytes=32 time=715ms TTL=52
Reply from 74.125.233.63: bytes=32 time=713ms TTL=52
Reply from 74.125.233.63: bytes=32 time=739ms TTL=52
Reply from 74.125.233.63: bytes=32 time=283ms TTL=52
Reply from 74.125.233.63: bytes=32 time=55ms TTL=52
Request timed out.
Reply from 74.125.233.63: bytes=32 time=490ms TTL=52
Reply from 74.125.233.63: bytes=32 time=689ms TTL=52
Reply from 74.125.233.63: bytes=32 time=916ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1120ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1419ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1746ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2179ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2655ms TTL=52
Reply from 74.125.233.63: bytes=32 time=3292ms TTL=52
Request timed out.
Request timed out.
Request timed out.
Reply from 74.125.233.63: bytes=32 time=552ms TTL=52
Reply from 74.125.233.63: bytes=32 time=528ms TTL=52
Reply from 74.125.233.63: bytes=32 time=643ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1024ms TTL=52
Reply from 74.125.233.63: bytes=32 time=1422ms TTL=52
Reply from 74.125.233.63: bytes=32 time=2123ms TTL=52
Reply from 74.125.233.63: bytes=32 time=3192ms TTL=52
Request timed out.
Request timed out.
Reply from 74.125.233.63: bytes=32 time=170ms TTL=52
Reply from 74.125.233.63: bytes=32 time=58ms TTL=52
Reply from 74.125.233.63: bytes=32 time=66ms TTL=52
Ping statistics for 74.125.233.63:
Packets: Sent = 100, Received = 90, Lost = 10 (10% loss),
Approximate round trip times in milli-seconds:
Minimum = 55ms, Maximum = 3648ms, Average = 1257ms
