ADSL speed problems in pretoria
midrian
hihi
We have 4x 1mb business uncapped adsl lines which over the past couple of months has degraded to the point where they are almost useless, and whenever I log the speed problem with IS they just connect the the cisco routers remotely and tell me everything is fine... how can I go about proving that the linespeed sucks and they need to work on it.
Could it perhaps be possible that our lines have been soft capped? downloads peaks at 600kb but then drops to nothing for a couple of seconds then peaks again... repeat.
overall download speed 30Kb/s if i am lucky.
Try resetting the ADSL router. For some reason my ADSL line regularly syncs at lower rates, going down to about 640 kbps. When the ADSL router is restarted it will try and sync again at the higher speeds.
