ADSL Sync problems
bravo16
I’m having lots of problems with my adsl dropping its sync. I’m running an Netgear router and the line just randomly drops maybe 15 or 20 times a day, and this is no exaggeration. I’ve logged calls with Telkom to take a look and the technicians basically just shrugs. About 5 or 6 of the 20 the sync light will die then I have to reset the adsl router and it works for a while sometimes a 2 minutes and it will drop again. The rest of the time the account just stops working (sync light just stand on a stable green light) then reset again and it works for a bit. I have multiple ISP accounts from different ISPs, I’ve jumped up and down spun 3 times and clicked my heals but with no luck. I’d appreciate some input.
