My parents-in-law are currently on dial-up with @lantic and are looking to move to broadband. Would like to avoid the 24 month tie-in if possible. Wireless router? Do they come as part of the package? If they use someone like @lantic, do they take care of connection/install etc?
Monthly cap can be as little as 2GB, mostly e-mail and some Skype
Speeds? No idea what is out there? What are best deals out there at the moment?
Any help appreciated
If they've been on dial-up, then the slowest ADSL via Telkom now is 1Meg.
That's more than fast enough for Skype (not video, I suspect) - probably a 2Meg. line would be better for that.
My suggestion would be for them to get Telkom to add the ADSL part to their line (better to not do it through a specific ISP, should they want to move ISPs in future. ) They can order that by either going to a Telkom Direct shop or via 10219.
http://residential.telkom.co.za/broadband-internet/broadband_services/adsl/order.html
They'll need to decide whether or not they're capable of doing a self-installation or relying on the Telkom tech. to do it for them, at an additional cost of about R600 added to their existing tel a/c. Sure you already know that it's not that difficult, but if they know nothing then if they can get someone they know to help them out, it'll save on that cost.
Next step would be, after the tech.'s come out to get the ADSL line sorted, to cancel the Dial-up with @lantic.
Depending on where they live, there should be retail shops near them that sell D-Link modems/routers (either basic wired for about R200 or wireless for about R500 to R600).
D-Link are in Pretoria on Tel No.: 012 661 2025 - they can suggest nearest shops.
My suggestion is to sign up also with @lantic for the Capped HOME option :
https://www.lantic.net/connectivity/adsl/capped-adsl/adsl-gig4gig#
1st GB each month is free & additional Gigs are a very reasonable R15/Gig incl. VAT.
(they may even just transfer them across to it, without all the forms, as they've got the details already for Dial-up).
Should they thereafter want a very reasonable Uncapped Bolt-on option :
https://www.lantic.net/connectivity/adsl/uncapped-adsl/adsl-uncapped-bolt-on
Though not mentioned on the above pg. that I see, it's also all weekend from Fri 6pm to Mon 6am
I (and others) can testify to both the above, now @lantic have sorted out their data usage to billing problems of a few months ago.
Particularly read the last few posts on the following link, but there's a whole history prior to now (in preceeding pages), where things needed to be sorted out - I can safely say that the Uncapped Bolt-on is now 100%.
http://mybroadband.co.za/vb/showthread.php/434391-lantic-R59-uncapped-bolt-on-feedback/page21
I find I get full line speed (1Meg.) through @lantic (my line's with Telkom, though) regardless of the time of day. @lantic don't throttle, from what I've experienced.
