Advice hardware
marine1
A black hole in the universe - JHB
Okay, so the monitors are basically the same.
I would go for the Hisense, given the options presented, as the Coby has internal speakers and that must mean if they cost the same that Coby skimped on the display components. Both 720p and energystar complaint.
Hisense looks better as well.
As for the wireless/wired switch.
What speeds do you need? Personally I would always go for a wired extension.
I used a NETGEAR Powerline AV+ 200 Nano Set because I wasnt going to chase the walls from the first level down to the bottom level of my house.
